Tires
Tires
Am in need of tires, and have it on good authority the Yoho Advan Neova AD08 are the bomb. sticky yet compliant. Me likey the sounds of that.
I have the turbo Cup 1's (7 and 9) The wheels currently run 215/45 & 245/45. Is there a better stagger for these wheel widths?
Thanks all.....
Thanks all.....
I think the wider rubber up front helps manage heat better at the track but if you're only carving canyons, I'd stick with 205/255 => lighter, sharper steering. Also, skinny tires are better in the rain (if you ever get any!) and you don't have the "rub" at full lock.
$0.02
$0.02
It's 205/50/17 and 255/40/17. Those are the stock sizes for 17-inch rims and give you a 25-inch OD front and rear. Looks like Tirerack has a $40 off deal on those tires.
http://www.tirerack.com/tires/TireSe...SortCode=50150
Have fun!
Have fun!
