particle filter on the 964
I had both my stereo and climate control unit out this past weekend and noticed there were some louvers back in there. I opened them with my fingers, and noticed what appeared to be a square paper filter of some kind. (The material looked similar to the engine air filter). I was wondering- is this a cockpit air filter? I haven't had a chance to investigate further.
sounds crazy not having a particle filter in a car.... especially with aircon, my Alfa Romeo's have one
and after one year use they are completely black !
the Germans must have stashed one in a secret place in the 911 !!!!
993's have cabin filters. they sit in front of the fan in the fan housing. 2 required (one for each front blower). Do a search on pelican for "pollen air filter" or 993-572-479-00.
Not sure if the 964 fan housing is the same size. If it is they should fit. Simply remove clips holding on part no 8 and slide in filter.
My AR also has a cabin filter but given the absence of a local parts dealer I remove the filter material and insert furnace filter foam cut to size into the plastic frame. Seems to work.
I would like to try the 993 pollen filter since I have everything apart. It would be nice to know if part 8 could replace the 964 part. It looks like it has latches for easy access to the filter.
sorry, none - except for this...
