Headlight switch
I need to replace my headlight switch. I've remove the electrical connector at the back and the **** at the front. It looks like it should screw out of the rose with 4 small holes that you can see when the **** is removed but mine won't budge. Should I just use more force or is there something I'm doing wrong?
Thanks in advance.
Thanks in advance.
