how to clear warning faults
I've been searching for instructions on how to clearn warning faults. If I remember right...you disconnect the battery terminals and touch them together. Is that correct?
Is there another way to do it.
How problem started
(I had some stereo work done today. they pass seat had to be removed temporarily for the install. when I picked the car up, the seatbelt and airbag faults were lit. The heat is blowing from behind the dash too...but that is I think just a disconnected hose behind dash)
How problem started
Burgled
make sure the green wire behind the stereo (alarm radio wire) is either hooked up or taped up on the end. If it grounds strange things can happen.
