Removing Autothority MAF & Chip returning to stock ECU Changes
I'm in the process of removing an Autothority MAF & Chip and returning my 94' Cab to stock. I read over on Pelican that there are some changes to the ECU that would have been completed for the Autothority MAF installation. These will need to be reversed for the car to run the stock AFM. There were no details on Pelican. Does anyone know anything about this?
Thanks,
JF
Thanks,
JF
I did this a few years ago. Good move. You need a stock Porsche chip to run in the ECU, or you can speak with Steve Wong about a replacement chip that can improve on a few things. It likely won't run with the standard AFM and the Authority chip installed. There is also a red wire that you will want to disconnect, and you can just tape it off. That's all I can remember. My car is so much better on the stock AFM and a Steve Wong chip.
Drop me a DM if you need more specific data.
