964 Wiring Questions
I have to go to a donor car to wire my ABS, Fuel Sender Unit and Fuel Pump.
Are these wires individual or on same loom ? Next question.....do they end up
at the fuse panel? As you have guessed, I removed my fuel cell and installed
the original gas tank. The original fuel pump wiring and Fuel Sender wiring,
has been removed. The ABS wiring harness has been removed and need to
know where to start from the donor car.
Thanks!!
Thanks!!
if i remember correctly, its all one harness. its comes into the trunk area from the fuse panel right below where the horns mount on the right side frame rail. then it splits with the abs and all the left side body stuff going frontwards around the tub andf the other half going backwards along the frame rail where the crash sensors are and then down to the pump area.
first picture you can see where it comes into the trunk
http://www.jetpylot.com/images/19909...G_0003_JPG.htm
here you can see it from underneath where it goes into the tub.
http://www.jetpylot.com/images/19909...G_0011_JPG.htm
and here you can see where it comes from the fuse panel.
http://www.jetpylot.com/images/19909...G_0017_JPG.htm
hope that helps..
Marc
hope that helps..
Marc
