suspension question??
Hey guys i was reading the service manual last night and in big bold letters it sais "Caution" not to tighten these (blue arrows) bolts until the car has weight on wheels.....
1) Curious as to why???
2) How am i supposed to get under there and tighten these with the car on the ground??
The bushes in the pic are p/u and function differently. Those bushes rotate past the fixed chassis bolt and must be kept well lubricated or they will develop friction and erode and squeek
W/ p/u bushes tighten up any time in any position because they will rotate anyway
Jerry:
If you switch back to rubber bushings, you have your excuse for getting a lift
Put some wood logs, bricks, ramps or something under each wheel and lower the car on these. Now the car is settled on the "ground" and you'll have enough space to tighten the bolts.
Thomas
Thomas
