964 Forum 1989-1994
964 Xenon Headlamps
Old 04-07-2010, 12:58 AM
wolv
wolv's Avatar
Default 964 Xenon Headlamps
I'm assuming someone must have stumbled across this site before but just to be sure, cause I can't read German.
Xenonlicht und Klarglasscheinwerfer
Umrüstung für 964 Modelle
http://apcardesign.server.hi-tech-me...non_kit_kl.jpg
http://apcardesign.server.hi-tech-me.../sw_xen_kl.jpg
http://apcardesign.server.hi-tech-me...4_xenon_kl.jpg
Looks pretty good. But listed as 1299 Euros......
Old 04-07-2010, 05:03 AM
doruiacovescu
doruiacovescu's Avatar
Why not these http://albert-motorsport.de/fahrzeug...einwerfer.html
177 Euro one
Old 04-07-2010, 05:56 AM
Jim Howley
Jim Howley's Avatar
One of the Turbo guys has the AP headlights fitted but I can't remember his username offhand. Do a quick search of the 964 and 964 Turbo forums and you should find it as it was within the last few months.
Old 04-07-2010, 06:38 AM
sergiDA
sergiDA's Avatar
I think his name is james or james watson or watson....
Old 04-07-2010, 08:27 AM
rarebear
rarebear's Avatar
the clear lenses alone cost 390 euro... outf*****nragious !!!
Old 04-07-2010, 03:39 PM
wolv
wolv's Avatar
Originally Posted by doruiacovescu
Any chance that site is available in English?
Old 04-07-2010, 04:07 PM
Rally Guy
Rally Guy's Avatar
Just hit "translate" if you have Google Toolbar installed.
RK
Old 04-07-2010, 04:08 PM
doruiacovescu
Hell Knows! It s easy to navigate.
I know that the whole 1 light assembly is 177Euro, non levelling type. Use google translate. it might give you an ideea about the things written there.
Old 04-07-2010, 06:17 PM
kylejohnston1
kylejohnston1's Avatar
So the Albert Motorsport assemblies come with 1 light...does this mean there is no high beam? Anyone have experience with these?
Old 04-09-2010, 02:01 AM
2002M3Drew
2002M3Drew's Avatar
The Xenons on my BMW and Saab don't change intensity either- they simply change the range of illumination upward for the high beams. The one bulb makes sense.
Old 04-09-2010, 05:18 AM
Cupcar#12
Cupcar#12's Avatar
one bulb and non-adjusting means no high beams.
by the looks of those they are a single adjusting xenon H4 bulb with a an H4 housing and a clear lens.
we need someone to adapt a proper design (true desinged Xenon) to the 964 ala ~
http://www.myhellalights.com/hid_xen..._Bi_Xenon.html
otherwise its just a rig job IMHO...
Old 04-09-2010, 11:56 AM
doruiacovescu
Wuthout leveling, means that you don t have the ability to aim the headlight to compensate the movement of the car's body after you put luggage etc. It s a feature only for european cars. It has 2 beams on a single bulb. The bulb moves a little bit forward. I have installed hid xenons on normal h4 headlights and it s a big pain in the a**. I get "friendly" flashes from the other drivers. And the high beam is not lighting in the place that it should. For me h4 with classic lights is still the best solution. may be a headlight with magnifier, like 993 has, it will be a good, proper upgrade.
Hope that helps!
Old 04-11-2010, 05:04 PM
Technomania
6th Gear
Technomania's Avatar
installed bi xenon a while back on my cabby...got the clear lenses from GT racing and the bi xenon kit of Ebay...material cost about 500,-
Old 05-30-2010, 12:25 PM
RAGH
4th Gear
RAGH's Avatar
Hi Technomania,
Are the incline/oval headlight reflectors standard on a cabby, or are they aftermarket? (the insides of the headlight unit).
Mine, and others, seem to stand up vertical and leave space between the reflector and the glass on the bottom side (like in the AP car design pics).
Kind regard
Edit: think i found the difference myself. Looking at pictures of headlight units on Ebay, if you try to look inside a headlight through the glass the H5 reflector seems to be different (oval, it fills the headlight completely) to the one in a H4 headlight (vertical, leaves blank space in the bottom of the headlight).
So it seems I need the reflector of a H5 headlight unit to imitate your look. Can anyone confirm?
Old 05-30-2010, 06:55 PM
Navaros911
Navaros911's Avatar
For some reason I don't think it looks "right" on these cars...
I'm tempted since it is the only thing I miss on the car right now... but can't get over the way it looks.
Quick Reply: 964 Xenon Headlamps
