I need some help with my 964. I have a backfiring/misfiring issue. Sounds like the intake filter box is going to pop off. Even trying to open the throttle yields no difference. My distributor belt is intact and my DME relay is fine. I replaced the DME with the 993 unit 3 years ago. Could it be an ISV or vacuum issue? I have done some searching but it that points me to DME and dist belts...
I recently did a clutch and tune up myself. I replaced the flywheel, pressure plate, clutch disk, etc. I put in new plugs and wires, dist caps and rotors. etc. It has been running great for the past two weeks (about 200 miles).
I ran some errands today with it. Then all of a sudden, this out of the blue.
Sounds like a misfire. What kind of spark plug wires did you install? How did the engine run prior to the tuneup? I'd double check all the work done relating to the wires, rotors, etc. and anything in the general viscinity of the installed components such as vacume lines, sensors near the flywheel etc..
The engine ran well before the tune up. It was one of those "while it's out" projects I wanted to do since the car just turned 65k miles. The clutch and fly needed to be replaced, so why not tune it as well. Anyway, I used the bosch plugs from pelican PN:999-170-183-90-M14 and I rebuilt the wire sets using new beru wires from a fellow rennlister with the original ends. Old plugs looked normal and old wires were in decent shape.
I rechecked a lot of the connections on top of the motor around the throttle and pulled the dist caps and rotors. I haven't checked the flywheel speed sensor or the plugs on the bottom of the car which will be tomorrows project. Would coils just crap out like this?
How would coils make backfire in the intake ?
I can see how crossed wires might , but he said the wires went on and the car ran OK for two weeks .
I'm thinking an intake valve is leaking fire into the intake system .
I would do a quick test of removing the two sparks to one cylinder at a time to try and find what cylinder is sending fire into the intake system and then check the valve clearance for that cylinder . Or I might try a quick/dirty "leak down" to try and find a leaky intake valve .
Another thing might be cross talk between wire causing a spark to show up at a time when an intake valve is off its seat .
I ran the plug wires one at a time as I replaced. Ran perfectly for a good number of miles.
I'll troubleshoot the coils tomorrow as well.
I can't imagine any way a bad coil could cause an intake system backfire ,
unless its an exhaust system backfire going past an open exhaust and intake valve and then into the intake system . The duration of the overlap is so short I guess that's only theoretically possible .
Broken exhaust valve system ?
Cylinder fires off half *** and then exhausts via the intake valve ?
