Better Rear view mirror..??
I have been taking my '91 964 C2 to DE and track events...Summit Point, VIR
Anyone know of a good replacement for the OE rear view mirror..?
The original is too old and too small...
I do not want to use a clip on or overfit mirror
I get passed alot , for now, and a wider field of vision would help me see which 997 or GT3 is bearing down on me....
Interested in a larger mirror assembly...
Thanks, Kevin in VA.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
This one should work... but it's looonnnnnngggggggg...
Wink Mirror, 5 Panel - 36 inches Long
http://www.pegasusautoracing.com/pro...asp?RecID=1546
Have you flipped your stock mirror? Just rotate it 180 degrees so that the wider part is on top. You'll definitely pick up more. Without a cage, thought, you're somewhat limited.
Have you considered overfit lenses for your aeros? Those things have an extremely narrow angle of view. They attach with double-stick tape and work great. I bought some from Performance Products for another car but, now, I have a BIG cage mount mirror.
