***Spacer size for my 964 with 10j ET59???????
Understand you clearly Mike, wont I be rubbing on the arch with an ET of 59 running on a 10J with a 20mm spacer adaptor? Even when running a stretched 255/35.
today i specially took me wheel of to mesure it up and i have to excuse me mate i use 15 mm adapters from H&R
so if you use 15 mm you don,t have to worry with 255 because i drive 265
