No Heater Blower Motor, should I still get heat
I have a question maybe someone can answer. My heater blower motor makes horrible noises so I have disconnected it so there is no power to it. Should I still get heat/air coming out of the front vents when the dial is turned to high and hot? Should the front vent blowers still work without the heater blower on the motor?
My car is a florida car that I have brought up to Canada, not sure if PO disconnected everything to do with heat since he did not need it.
Yes you should, but you have to jump wire the fan realy in the rear. Otherwise the CCU thinks there's a problem with the fan and shuts down the system when you turn up the heat. If the error has kicked in (gives you only low speed on front blowers and no heat) you have to use the Bosch Hammer/or Scantool to reset the error codes.
I've attached a pic showing you how to jump wire the relay. This is the same thing you do if you want to use the bypass tube from the cup cars instead of the rear fan.
Thomas
Thomas
Thomas - thanks for pointing me in the right direction. I will try that.
Jim - you guys have almost had more snow than us here in Canada this year.
My blower motor similarly died, and I think you will find the airflow without it quite lacking , even when jumpered.
If you choose not to replace the blower, a good option is to get a bypass tube.. carbon fibre ones are available from fabspeed and elsewhere.
As a cheap alternative I would suggest removing the blower motor assembly from the housing. This gives you a setup very similar in function to the bypass tube, though perhaps somewhat less efficient.
Let me confirm this... (sorry to hijack)
when installing a heater bypass tube (functional heat, albeit reduced velocity) , all you need to do unplug the wires, unbolt it, and set up a relay jumper (as in Thomas' picture)?
On my '93 the heater blower makes a terrible noise so I have the fuse pulled.
I get PLENTY of heat into the cabin even with the heater set at 12 o'clock and no fan on.
I can cook my face if I turn the heat all the way up.
No jumpering required....BUT I don't get any heat on my feet. ?
One issue that you may run into that the 964 has is if you jump the relay it leaves a circuit open for some reason and drains the battery - What some of us have done is install 2 relays to do what the 2 wires do, but only when activated by an ign switched control wire - if you probe around you can find one in the rear fuze box to run to the relays.
Well I did what Thomas said to do and it worked. I'll see if I get a battery drain issue.
Gus, can you elaborate on this for me, not to good with electronics. What two types of relays should I use and where should I get an ign switched control wire. How do I put two relays into that one spot.
the battery draining is a bit strange. I don't have it, from what I know at least. I always use my trickle charger when the car sits in the garage and it's more or less always in "rest-mode".
Thomas
Thomas
I am using the carbon Heater bypass tube, same as in the cup cars , and the fact is that I have no heating at all. Here in Barcelona is not a big issue, but this trick you just showed us will help to get at least some hot air inside which is not a bad thing at all.
Thanks a lot!!
Thanks a lot!!
