964 Forum 1989-1994
Manual raising of the spoiler
Old 02-19-2010 | 08:17 AM
Jim Howley's Avatar
Jim Howley
Default Manual raising of the spoiler
My car is going off for a respray shortly and I will be replacing the automatic spoiler with a fixed wing which bolts to the standard 964 decklid. However the spoiler control module on my car isn't working so is there any way to manually raise the spoiler in order for me to get to the fixings and remove it?
Old 02-19-2010 | 12:56 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Yes. You can disconnect the cable that runs from the electric motor to the spoiler raising gearbox. You can either manually spin the cable or use a cordless drill. I had to remove my spoiler gearbox to repair a failed bearing and I use a cordless drill to test and verify that the gearbox was installed correctly.
http://p-car.com/diy/spoilerdrive/
Old 02-19-2010 | 01:54 PM
Jim Howley's Avatar
Jim Howley
Perfect. Thanks Rob.
