Disconnecting airbag from steering wheel?
Gents, I presently have the airbag dismounted from the steering wheel. Can anyone tell me where to disconnect the wiring harness from? It doesn't appear to disconnect from inside the steering column. The wiring harness goes directly to the back of the air bag and has a red connector. I'd be grateful for any hints.![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Dan
Dan
Agent Orange
It's in the center console and it disconnects both airbags. I believe joey bagadonuts had a how-to thread on it a while ago. You can get a bypass plug with a 928 part number I believe, but it's pricey. Or you can cut and splice the wires, but make sure you leave enough on both ends to put it back together one day if you so desire. You disconnected the battery before taking the air bag out, right?
Thanks for the advise and thread Ilko, I did disconnect the battery for 2 hrs just to be on the safe side. I also disconnected the plug in the console. Waiting for the bridge plug to come in from my parts guy. Now comes the fun part of mounting the Momo steering wheel.
Thanks again for the help as usual,
Dan
Dan
This will save you a load of hassle,and no one seems to mention buying this part .
Steering Wheel Horn Contact Porsche 964 / 993
Code: 96465210400
Use with Porsche 964 and 993 models cars which have an steering wheel airbag.
Order when ordering Part No ID993347084808YR
- Porsche 964 1990-94
just clips in and the horn button works straight away.
hope this helps,Gaz
Code: 96465210400
hope this helps,Gaz
Agent Orange
I believe that horn contact is mentioned in the thread above. And yes, it is crucial to get it in order to have a working horn button.
Installing the Momo wheel was fun, I remember wrapping a .5L plastic water bottle with some 200 grit sand paper and widening the hole in the steering column trim pieces. That was fun...
But once the wheel is in, you'll never want to go back to stock! What a great feel it has, I miss it!
Thanks Gaz, I ordered part number 964.652.104.00 for the horn with new trim pieces from a non air bag car. Should have the parts this Wed. to finish up this project. I hope... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Ilko, I'm really looking forward to the new wheel and getting rid of the bus wheel.
Dan
Dan
