Battery Disconnect Switch - Pos or Neg?
Hi everyone
I've bought a battery disconnect switch so that I can easily disconnect the battery when I'm not going to be using the car. The negative cable on the car is too short to put it on that terminal. Is it OK to put it on the positive terminal?
Thanks!
Thanks!
Our club rules require the postive side. One note Andy, if you kill the power the ECU that controls the engine will reset each time. This can be a good thing or bad depending on what ignition map was stored. If you want a more aggresive engine map on re-energizing the system then drive it like you stole it for a little while each time. I just ran a CTek charger on my 964. The turbo doesn't have this issue.
Thanks. Any excuse to drive it like I stole it is a good excuse! It's in a car park where I don't have the option to plug in a trickle charger unfortunately, so I'm looking at this to eliminate the chance of a flat battery from the alarm draining it as I can just unplug it when I'm not using it.
