Big blacks on 964
Big blacks on 964
Hello! I found this brake calipers. 86.5-91 brembo -Part# 92835142203
The part number for the big blacks are 928 351 423 03 & 928 351 424 03
Anyone knows if they do fit properly on a 90 c4? Are they big blacks? THe PN is not actually the same as the big blacks's. What s the difference beetwen them?
Please double check but I think they are the same except the hard piped brake line on the caliper is mounted on the opposite side of the caliper vs. the 964. This line can be moved and then you should be good to go. The 928 had the caliper on the opposite side of the rotor as the 964. Please check me on this as this info is second hand.
It's unclear to me what you are asking about
there are several different calipers that you can use for a 964 bbk
there are 3 basic sizes, some black, some red come silver, color is not a good identifier
the largest caliper uses a 132x58mm pad and came in red leading mount or black trailing mount, the 964 needs leading mount so the trailing mounts need to have the bleeds and feeds swapped.
the big caliper uses a 132x48mm pad and for front mount came in black and silver, and black for trailing mount, again for use on a 964 the trailing mount calipers needs to have bleeds and feeds swapped. 928 351 423 03 & 928 351 424 03 are black trailing mount calipers in this size class, note that they are not the larger aka "Big Red or Big Black" other calipers in this size class are the 993 front and 965 3.3t front and 964RS front. All the 964 and 993 calipers are leading mount, the are all hydraulically equivalent and all use the same pads. The difference is in the rotors they will want. the 964RS and 965 3.3t will want 322x32mm rotors the others 304x32mm rotors, there are several different 322mm rotors some are 2 piece some one, some have 964 o/s some 993. There a re also several different 304mm rotors. All can be used but you need to be careful is selection to have matching components.
all of these above fronts will want 993 rear calipers and a bigger 23.8mm 993 m/c
Yes, forgive my lack of accurate description. Recap
1. These: 86.5-91 brembo -Part# 92835142203 are big blacks?
2. I understand thath these: 928 351 423 03 are exactly like big reds and they are big blacks. Clarify me on this.
3. What s the difference beetwen first caliper and second?
The only big blacks came on either the 94 turbos which could be special ordered in black instead of red and the 928GTS which all used the same 322x32mm rotor but the 928 had a non-crossdrilled version.
So what you are looking at ar not big blacks but medium S4's
Hope this helps.
