Rollbars and Seats - Who is using what?
The sliders have mounting holes on the bottom that line up with the Factory mounting points--both the Recaro's and Sparco's. You attach them to the brackets, first, and then bolt them to the Factory mounting points.
![](https://rennlist.com/forums/members/joey-bagadonuts-albums-parts-and-diagrams-picture3493-speedsterseat.jpg)
The '92 C4 had a used Autopower bar and some Kirkeys with modified stock sliders.
RSA #1 had a Safety Devices cage and the same Kirkeys, but fixed mount.
The yellow 993 (basically the same car, right?) as I bought it equipped and have never taken apart, has (I think) a good bolt in roll bar and Recaro fixed back seats with sliders.
RSA #2 is 100% stock, and while those seats are heavy they do work really well!
1) oem manual double locking which are hard to come by
2) Recaro flat
3) Sparco
I tried #2 & 3, w/ 2 being best, but they won't bolt on, at best you will need to drill a couple of holes in the sliders at worst you will drill a whole new set of holes. It will depend on how much leg room you need.
No, it will be a royal bit** for some of the seats not so much for others it all depends on what seat and sidemount and slider combo you choose.
I am mostly familiar w/ Recaro, the wider the seat the harder it will be to fit, the longer your legs the harder it will be to fit,
widths from narrow to wide
oem Cup & SPG < oem RS & pp < SPG XL
which seat also depends on your shoulder height, you need a straight run(or just a tad down) from the top of your shoulder to the harness attachment on the rollbar.
SPG XL and GT3 seats are most flexible in this regard
How about the fabricate-your-own option? Always fun first thinking you can knock something out in 1/2 day, then on day 2 you wonder what you were thinking.
(You can tell which option I usually start with.)
