964 Forum 1989-1994
Goup Buy-Hargett Precision Aliminum Valve covers
Old 01-25-2010, 02:06 PM
FisterD
FisterD's Avatar
Default Goup Buy-Hargett Precision Aliminum Valve covers
This was a 993 Group buy, that has now been opened up to the 964s.
https://rennlist.com/forums/993-foru...group-buy.html
Old 01-25-2010, 02:13 PM
Geoffrey
Geoffrey's Avatar
Do the lower valve covers for the 993 have the holes for the spark plug clips? Do the lower valve covers for the 993 have machined in clips for the spark plug wires? If not, how are the lower wires held properly?
Old 01-25-2010, 03:05 PM
altarchsa
altarchsa's Avatar
Sure, wait til I buy mine then everyone get together.
I've had mine for the 964 about a month and the lower covers do not have holes for plug wire clips.
Old 01-25-2010, 04:27 PM
altarchsa
altarchsa's Avatar
Originally Posted by Geoffrey
....If not, how are the lower wires held properly?
I used some rubber covered metal wire clips for attaching electrical wire to surfaces for mine. They can be found in the electrical departmant at Lowe's and Home Depot. They're "P" shaped, similar to electrical conduit clips, but smaller and with the rubber insulation. I just put them under the washers and nuts used to hold the covers on. Works great. The extra "washer" doesn't seem to be a problem with the extra stiffness of the Tarett covers.
Old 01-25-2010, 04:39 PM
GoKart
GoKart's Avatar
What is the purpose of installing these? Are they purely cosmetic?
Old 01-25-2010, 04:43 PM
jimq
Burgled
jimq's Avatar
they replace the plastic valve covers used on the 993's
Old 01-25-2010, 04:49 PM
GoKart
GoKart's Avatar
Are they an upgrade of some sort for 964's, then?
Old 01-25-2010, 05:29 PM
hawk911
hawk911's Avatar
cosmetic, mostly.
Old 01-25-2010, 05:35 PM
jimq
Burgled
jimq's Avatar
I thought the 993 valve covers didnt fit on a 964?
Old 01-25-2010, 05:40 PM
xeps
xeps's Avatar
I believe hargett makes a valve cover specifically for the 964
Old 01-25-2010, 06:54 PM
Geoffrey
Geoffrey's Avatar
The early 964 valve covers are magnesium so over time they pit and have warping issues. Later 964s use aluminum which work much better.
Old 01-25-2010, 08:32 PM
Crank
Crank's Avatar
Would that cause leaks from the valve covers?
Old 01-25-2010, 08:46 PM
Geoffrey
Geoffrey's Avatar
It could.
Old 01-25-2010, 09:01 PM
Duck
Duck's Avatar
Mine were early magnesium and the paint was seriously flaking inside and out. I replaced all with Hargett. It does not have the plug wires holder, but I have Heat Sheets which work great for holding and protecting the wires.
Old 03-31-2010, 04:10 PM
MB 911
MB 911's Avatar
what are Heat Sheets and where can I get them. I am about to replace my valve covers.
Quick Reply: Goup Buy-Hargett Precision Aliminum Valve covers
