New bushings won't fit!!!! Need advice.
Professor of Pending Projects
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
![](http://i243.photobucket.com/albums/ff169/rennsport751/IMG_9647.jpg)
I'm still having a bit of an issue. The distance from hat to hat is about 4.5mm too large to fit back in the car. I realize it's supposed to be a tight fit, but this will just not go. The area where the bushing flange rests on the arm has some excess material from left from the casting process. The problem with the oem style bushes is that they can not be removed easily to fine tune the fit.
Light at the end of the tunnel, though.
Hi Jonnygo1,
Can not understand if the supplier has given you the correct bushes why they shouldn't fit
are you sure they have given you the right ones?
I used Powerflex bushes, they are highly rated and loads of people in the UK use them. I'm sure they would post overseas, here are there contact details, should you want to make some enquiries, www.powerflex.co.uk or sales@powerflex.co.uk or tel: +441895460033
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
