mist in the car
mist in the car
Hi guys,
I took the car the other day and it was raining a lot outside temp was 10 deg C, I had a lot of mist on all the windows, and could not clear it with the fans, i had to use the aircon full blast, and time to time switch it back on as the mist was coming back, the fan and heating system are working perfectly and the aircon as well, any ideas, thanks
Konstantin
Konstantin
How much moisture is in the car? Are the carpets wet? Also, check the A/C drain tubes to be sure they are free of debris. Look under the car for the vents. (search on this forum too for blocked A/C vent or leaks)
Mine had some excessive misting recently. Particularly the dials in the dash. I found that the sensor pictured below had popped out of one of the cabin fan housings (there's one each side). I'm not sure what it is but once relocated snuggly the mist cleared straight away.
