Now calling BRITS, how many are there here on Rennlist?
#78
Windsor based and generally use 911uk and PCGB Forum. But love the photos's on here and enthusiasm of all the guys on the other side of the Pond
Have
964 RS Touring (RHD)
964 RS N-GT (Clubsport)
Pictured with the 993's
Have
#79
Prestbury!
Nice part ov the world, big money. Prestbury? More millionaires per mile than anywhere? (i cant spell?)
U ok sal? Hows the turbs?
And Sten(baz) i need your help.
Ive been told your fantastic with 964 ABS?
If and when you got time can i gain your helps?
The flash has no ABS?
Not a biggy cos iam such a fantastic driver, but my calf muscle is no where near as quick at on/off as a ABS pump.
Can u help?
Can u help?
#80
love the collection! read this in GT Porsche, only a few 964RS with sunroof!
#83
Prestbury!
Can u help?
Can u help?
I've just had a similar ABS issue on my C2 and eventually tracked it down to a duff relay (main one in the fusebox) after Jonny checked the sensor lead resistances to no avail, so I swapped some bits from my Dad's C2 to eliminate the faulty parts!
To be honest, without having the ability to swap the ABS brain, 3x relays etc with known good ones to try, then you could be there a while!
You are more than welcome to come and use my car to swap bits, as it were!
Cheers
Nick
#84
Hi Russ,
A combination of faults is always tricky, easiest way as Nick says is to 'borrow' parts from a working car. I'd start with the relays if you can, both of mine (which are of course different on a C4) on the ABS pump were duff - I've got spares of these, need to check if they're the same. I know Jonny tried a spare ABS ECU on your car, what condition are the pins in the connector - these are known to cause problems in our warm, dry climate (not).
Nski,
That's not my car, but I'm sure I've seen it somewhere. I live in Halewood Village, about 5 minutes from Tech 9.
Seasons greetings to one and all!
Baz
Nski,
Baz
#85
Arhhhh Baz a local guy, I knew of Tech9s unit since I was a kid, as I used to hangout at a friends thatched cottages opposite.
Have to hookup sometime, as I only work only near Jaguar car showroom on the greenbelt road leading to town.
Merrry Christmas and a Happy New Year ;-)
Nice to see loadds of owners from the UK and lovely cars too!
#86
hi all i live in banks near southport n/west coast ive just joined pcgb and just found this site love the cars and realise got a long way to go with mine there gourdous cheers ray
#87
Any help will be greatly apprciated.
When the wheater gets a bit better ill have to come and c u appleton, mayb you can give me a hand to get this stupid abs workin
Baz with you car bein a c4 theres not many parts that are the same.
#88
Russ, one thing to check with the ABS - are your brake lights working? The ABS controller relies on the brake light switch to tell it if you are trying to brake - if the switch is faulty you can end up with no ABS. I had exactly this on my car, replaced the switch and all worked again.
#89
Originally from Scotland now down in Maidenhead, Berkshire.
Not on here that often recently - hopefully get to a couple of the meets next year - happy new year all!
I have a 1990 C4 Cab - post some piccies when I dig them out.
#90
Prestbury!
Can u help?
Can u help?
