to widebody or not...
i need to replace my front wings... going grp - and also cut some rust out a rear arch.... so the question is, do i go for a fat ***??
You can convert a 964 to a 993 RSR (extra-wide body) using Getty Design fiberglass bits. It allows much bigger wheels/tires (I run 11" and 13" slicks f/r).
It's great for a track car. I would not use fiberglass panels on a street car as they are too fragile - you can not lean on them with impunity and they get damaged from stones (paint stars). Also, it greatly increases the aerodynamic profile and drag is increased. Make sure you need wheels that wide before you sacrifice that much on the straights.
interesting, the BBS at the rear could do with 295 minimum really, 265 look a tiny bit to narrow... it was just a thought, while replacing, why not go wide.
inboard to outboard up front is easy enough wont cost anything.
rear, i guess spacers for now until i come across a pair of arms.
undecided, may just repair what i have here for now... hmmmm.
