What are the best "bang for your buck" 964 mods???
Agree on the alignment. With 275 rears and RS alignment my car is a pain in the *** on the highway with 18 wheeler ruts, etc. If its a toy, do it, otherwise lighten it and try the chip and better exhaust.
Car feels lazy : Superchage it you will always have this face
everytime you drive it. However just like many great things it will be costly..but worth it IMO.
sturm: Shorter 3,4,5 gears really did it for me.
GeorgeK:Once you feel the car is keeping you from going faster, you can lighten/stiffen/add power as needed.
I wonder how many on this forum know how these cars drive when they are to factory spec, i.e. with good condition drivetrain.
Good advice from both, and I'd add a lwt flywheel/clutch.
You're trying to accelerate a 3000# car with 250hp. No fun. Lazy is sure.
Spend my money, but don't waste it please.
- drill your airbox cover. Great roar at 4K+ and WOT!
- primary bypass. True Porsche Cup sound. Fan noise, induction noise, mid RMP thunder, redline roar.
- Wevo motor mounts (blk). Solid, direct feel. + stability tight corners. A little more cabin roar.
- Strut brace
- Wong chip. Sharper, stronger mid range. 93 Octane. LWT Fly compat.
- Remove rear seats and trunk carpeting.
I wonder how many on this forum know how these cars drive when they are to factory spec, i.e. with good condition drivetrain. I know mine has 140+ Kmiles on it, so wil not deliver as intended in 1989.
Understood.
- Strut brace
- Strut brace
I have a primary bypass and it does not drone. Some people like the g-pipe (secondary bypass), but it seems to be louder and not remove weight of the rear.
I agree. That is what a Porsche is supposed to sound like.
Agree w/ GeorgeK.
(though burning-out & cleaning steel inserts from front suspension bushings is something I never want to do again!)![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Also, I've a feeling the Steve930T was looking for a Better-Driving-Through-Equipment solution set. Lord knows, I've been there more than once.
Long story short I bought a 91 964 in the spring that I was going to drive for a little while and re-sell. I was never a big fan of these cars, but this one kind of found me and it was a deal I couldn't refuse. Well, as it turns out I REALLY like it and now I want to do some mods. I already have cars with track suspension, harnesses, no heat or air etc... and don't want to go that route with this car.
I'm looking for opinions on exhaust, chips, clutch etc... What's going to make this car more fun to drive without it having exhaust drone or being difficult to drive? It feels kind of lazy or heavy now. Right now it's all stock except for H&R coilovers and Speedline wheels. I'm also looking for a fiberglass carrera tail and front splitter for it. Spend my money, but don't waste it please. Thanks.
I think the primary muffler bypass will be the start and then possibly a cat bypass. Does anyone have any of this stuff available used? I found a bypass pipe on ebay by maxspeed...has anyone here bought one? I also need aero mirrors for it. What LWF should I get?
As for the suspension, I changed the bearing plates and ball joints when I did the coilovers. The bushings are all in real good shape. I may upgrade the sway bars. Any recommendations ?
I have two track cars so this one won't see anything but street driving. I just want some more power, better sound and improved handling....and cold A/C. Thanks for the info.
How did you like the mass flow sensor? I had one on a 3.2 that worked well but didn't idle well some times.It did make more power than the Wong chip and stock AFM.
As others have said, but I would put suspension toward the top of this list. It tranforms the car and makes it feel much more responsive. I used Bilstein PSS9s on my daily driver 993 and it made the car much more fun and did well for occasional track duty. My 964 has Motons which are a little much for the street (although I'm going to be driving mine diaily for a little while).
It is? I'm around -1.5 front/-2.0(or more) rear with the RSA. Drives just fine with the 225/255's now; when I had the 235/275 RA1's and could still use them as a street tire they were also fine. Not that I've ever driven this car much on the street. Old RSA racer wanted even more for the Hoosiers.
