Idle Erratic when Engine is cold
I would also clean the isv with motor cleaner until you can hear "clic clac" when you shake it.
I had the same problem and it was 100% solved with this.
Good luck!
Good luck!
How is your battery?
I took a (very) quick look at mine over the weekend - I started it up while logging with Durametric. There are actually not that many things I can monitor live on the 964 (much less than the 996) but I did monitor engine temp and voltage. Engine temp looked fine to me, but voltage was low - often reading 11.7-11.8v.
I don't know how accurate that reading was, but I know these cars don't like low voltage so I'm wondering if I have battery problems. I was told years ago my alternator output was below spec - I leave my car on trickle charge, but I have suspected for some time the charger might not be working. I'm going to pick up a new charger and see if that solves my problem.
Don't forget to check that the car will run on either coil also - disconnect each LOW VOLTAGE lead under the coils and make sure the engine will run on either. Mine had corrosion on one of the connections and wasn't working while cold.
Mine did the same thing, real irradic idle and sometimes stalled.
I cleaned the ISV and it was rock soild for a week or so and now is starting surge +50 rpm at idle.
I think my control valve is iffy at best, some from before I got it has worked it over pretty well.
I also replace the O2 sensor, DME relay, reset DME, it idles and runs better but not quite perfect yet.
I am planning on Coils, ignitors, wires over the winter and it's due for a valve adjust.
I'm only having a cold start idle issue...the car wants to stall at first start up. Need to keep on the gas. 100 yards down the road and it's not an issue. Once warm works perfectly. I'm hoping I just need to clean the ISV...the one thing I didn't do when I had the shop in Indy do a 60k service. Oh, that and maybe a new O2 sensor. Everything else is new or newish.
Thanks for the help!
1 Post
I apologize for not responding quicker. I've been out of town with no internet access. You may have already solved your dilemma, but to answer your question, I did get my idle issue fixed by adjusting the throttle/microswitch making it a bit richer. I also added a can of LubroMoly fuel injection system cleaner and 2 cans intake valve cleaner per mechanic's suggestion. I was very surprised that the idle does not hunt any longer. I also switch to Brad Penn synthetic (10w/40) from Mobile1. Overall the engine sounds great- at idle or on high RPM. In the future, I intend to replace the O2 sensor and the plug harness/wires. These are 2 items that have not been replaced for at least 40K miles according to my records. Good luck.
Ryan
p.s. I also cleaned out the throttle body for oil residue.
When I start my 964 after not driving it for about 5-7 days the idle is erratic during start (to the point where it wants to cut off). I have to put some gas to keep it from dying. But when the engine warms-up the idle is okay again. Is there something I can do to remedy this idle problem? Or is this normal after 5day storage?
Thanks!
Thanks!
Get a charger that goes through the correct cycles. Desulphation, soft start, bulk, absorption, recondition, float. Then your car will start and idle great from start up after a week.
