964 Forum 1989-1994
Reducing Unsprung Weight
Old 10-16-2009, 03:42 PM
Bill Verburg
Bill Verburg's Avatar
Originally Posted by ACSGP
So Biil, 2 things:
1. Has anyone installed a 993 rear suspension on a 964 yet; and
2. On the light rotors, the larger, floating rotors are supposed to shed more heat than the solid one piece ones, so not so sure about your comments abt compromise.
1) I never impied that 993 rear suspension could be used on a 964, only that 993 fixed many areas that were lacking in 964, 996/997 further refined the process in most areas. Nothing to be defensive about.
2) heat shed from the hats is minimal, yes, alumium floating hat sare nice to have but the differences from stock aren't that great. Besides which no generally available 964 used separable hats. The compromise the factory sold was one of track suitability vs cost, for street 964 is was biased to cost for RS more to track but stil w/ a long way to go.
Old 10-16-2009, 07:21 PM
Tom W
Tom W's Avatar
I have floating rotors with aluminum hats on the Turtle. I would not do it again, I don't think it's worth the cost and effort.
Old 10-17-2009, 01:07 AM
ACSGP
ACSGP's Avatar
Not sure what you meant by being defensive. Simple question, can a 964 upgrade its rear suspension by installing a 993s? I'm doing that for the engine via installing the Varioram next year as advised by Colin.
Old 10-17-2009, 10:59 AM
Bill Verburg
simple answer no, not easily, not so simple answer anything is possible if you throw enough time, effort and money at it.
Old 10-17-2009, 07:07 PM
Robert Linton
Robert Linton's Avatar
One recently retired Porsche engineer put a 993 rear suspension on his 964.
Old 10-17-2009, 08:11 PM
LA964RS
LA964RS's Avatar
You can stick a 993 rear suspension on a bunch of stuff I've even seen it used on some kit cars. Just if you build a subframe to bolt it to, then things get heavy quickly.
Be interesting to see the structure the Pcar engineer used for the install.
Old 10-17-2009, 08:16 PM
ttAmerica RoadsterAWD
ttAmerica RoadsterAWD's Avatar
Hi Robert...have any info on this 993 rear end swap?
Old 10-17-2009, 08:21 PM
Robert Linton
I have just sent an email to the engineer in Germany.
Old 10-18-2009, 03:32 AM
ACSGP
ACSGP's Avatar
Thanks Robert. Would appreciate if you could keep us all posted.
Old 10-24-2009, 06:54 AM
ACSGP
ACSGP's Avatar
Anything heard Robert?
Old 10-24-2009, 09:18 AM
springer3
springer3's Avatar
Originally Posted by junkart
.....For example, wheel A and wheel B have the exact same weight, but wheel A is a mesh design and wheel B is a 5 spoke design. Wheel A will give you less unsprung weight because most of the weight is at the center hub area and lighter on the outer rim area compared to the B wheel. .......
Unsprung weight is unsprung weight, no matter where it is distributed. You are refering to mass moment of inertia, which is lowered if you distribute the mass closer to the center. Ride and handling improve with lower unsprung weight. Acceleration is the only thing you improve when you move the rotating mass closer to the center of rotation.
Old 10-24-2009, 09:15 PM
Robert Linton
No word yet.
Old 10-25-2009, 12:24 AM
Gasser
Gasser's Avatar
Well, for me, I just moved from stock class to GT class and dropped around 500 pounds. I dropped 3 seconds a lap easily. Had to do a lot of last min suspension changes but once dialed in I was instantly faster. Been driving that track for years. I also use aluminum center hats/ floating rotors and I like them. Much better than the stock stuff I was using. Much more durrable.
Now Im just focusing on moving weight down and towards the center of the car. Car should be 2390 or so minus fuel. Ill have to add just a little lead for My class but that will help me corner balance the car a little easier.
I have heard of some removing their rear emergency brake stuff. Not sure how much weight this saves. I only use that brake durring transport. worth taking that stuff ouf of the rear rotor? Less rotational friction? Thoughts...
I love driving a light car, especially my 993.
FWIW
Old 10-25-2009, 11:49 AM
joey bagadonuts
joey bagadonuts's Avatar
Good data point, Gasser, and congrats on the improvement.
I was wondering if you could expand. Did the improvement come from improved cornering speeds, acceleration, shorter braking or all of the above? Or was there something else? Also, did you make other mods as you progressed to GT, e.g. slicks, cams, compression, intake, ecu, etc?
Old 10-25-2009, 06:51 PM
race911
race911's Avatar
I think Tom has the most developed (to a set of rules) 964 chassis car in the country now? There's some wisdom to be learned in his comments. He was all smiles after Saturday's race, even though he got nipped for a position at the end. (Not there today, so maybe even better results!)
So anyway, the Spec 911 (NOT Tom's class) field gets their trophy weight after qualifying yesterday, and most of the guys have to add 150 lbs. per the rule structure. Guess what happens during the race? Fastest guys are still fastest (Van Overbeck--yes, Johannes' dad, Gamroth--yes, the engine builder, and he had to start sixth because even though he was pole sitter they do a straw draw to potentially invert the top six starters), and the race fastest lap times are near equivalent to qualifying.
Quick Reply: Reducing Unsprung Weight
