Durametric Diagnostic Tool on '91 964 - limitations?
Hi
I had an "Air Bag/Safety Belt" warning light on. I searched around and ended up purchasing an Enthusiast Version of the Durametric to reset the lights and find out what the problem might be (Left sensor).
Upon connecting and finallhy understanding the basics I found out that the tool does not provide data on: Tiptronic & Alarm.
At times it comes up with a "Unknown DTC" and "Failed to Initialize" on some modules. I have contacted their Service Dept. and am waiting for suggestions.
Anyone have a similar experience?
Also the Heating/AC diagnositic comes up with a number of faults (24, 43, 45) but I have not observed any HAC malfunctions. Resetting them works for a while, but some come back.
Comments please.
Don S
Comments please.
Don S
On my 964 the Air Bag/Safety Belt light would come on after being reset two different times. Once by the local Porsche dealer and they supposedly cleaned all the contacts then reset. But after a few hundred miles it came on again. Cory at Planet9eleven reset again and the diagnostics on his claimed it was the right front sensor. I read on several forums that the clock guage had several bad connections associated with our cars and needed to have the solder joints redone. As described I performed the DIY from here http://p-car.com/diy/clockrepair/. Went back to Cory to reset the computer again and so far after 1200 miles the warning lights have yet to return. Good Luck.
+1 on the clock resolder. I did mine over 4 years ago, and still no warning light!
As for the Heating codes, it is common on the "scantool" that many of us use - it has to do with a race between the code reader and tne ECU when it is first turned on. Reset and rescan, if no codes pop up, then it's OK.
I use the same tool. The tip diagnostics works on mine and has indicated a fault before. Maybe the OBD plug is dirty?
It has always worked without the engine running. I also used the HVAC to repair my system. It should list the fault next to the code, for instance, 43 and 45 are the front and rear blowers I believe. Both of them were faulty resistors. I also think 23 was the interior sensor motor. After you reset the code, it will show back up if there is a legitimate fault. I use the durametric on both the 964 and 986 and it has already paid for itself.
I've had good success with the software, however, at times it does not read the ABS system. I have found Durham to be very helpful when I had an issue in the past with resetting the clock (which turned out to require a firmware update). The software creates a log file which you can send him in the case you think something is not being reported properly.
tom
tom
