964 Forum 1989-1994
oil pressure
Old Oct 5, 2009 | 11:00 PM
wellcraft290's Avatar
wellcraft290
Default oil pressure
Whe I idle I am about 3 bar but once I hit the gas i go to 5. 4 maybe if just slightly on the throttle. Is that ok or is there sometimes too much oil pressure? I use 15w 50 oil
Old Oct 5, 2009 | 11:04 PM
Wachuko's Avatar
Wachuko
Professor of Pending Projects
At idle it should be closer to 2 bar... and then move to 4-5 as you rev away... normal
Old Oct 5, 2009 | 11:05 PM
Wachuko's Avatar
Wachuko
Measure your oil if you think is overfilled...
Car must be warm (normal operating temperature). Level surface, at idle... measure via dipstick and gauge (should be around 3/4 in the gauge)...
Old Oct 5, 2009 | 11:07 PM
wellcraft290
oil level is fine just around 3 or slightly higher at idle then pinned at throttle
Old Oct 5, 2009 | 11:17 PM
darth's Avatar
darth
Hi oil pressure may be an indication of restricted oil passages just like clogged arteries and hi blood pressure in people. Maybe your guage or sender is out of calibration or defective. You can verify the pressure by connecting a good quality oil pressure guage to an oil port.
Bill
Old Oct 6, 2009 | 09:24 AM
911Jetta's Avatar
911Jetta
My warn idle is at 1.5 to 2 bar.
Old Oct 6, 2009 | 12:49 PM
dan79brooklyn's Avatar
dan79brooklyn
My warm idle is about 1.5bar with 10w-40 synthetic.
Old Oct 8, 2009 | 12:54 PM
Christer's Avatar
Christer
If it is 3bar when the car is fully warmed up then its higher than any other 964 I have seen. Is it fully warmed up and oil cooler open when this happens?
Old Oct 8, 2009 | 01:27 PM
wellcraft290
I will have to keep a closer eye on this. If I am at 3 and should be lower what should I look for? I know the oil tank oil lines and pump were replaced two years or less ago.
Old Oct 8, 2009 | 03:09 PM
Wachuko's Avatar
Wachuko
Cool
Is the gauge smooth? Does it moves smoothly from 3 to 5 and when in idle it stays calmly at 3? Or do you see it having erratic behavior?
If you see some erratic behavior it is most likely the sender at the engine (either a bad sender or bad contact.
Old Oct 8, 2009 | 06:50 PM
wellcraft290
I have a LWF and chip so the motor idles around 850-900 not hunting but not flat so teh pressure moves slightly. It really just goes up when I hit the throttle goes up.
