Noticed tonight, if i turn to ignition on, the fog lights, which are also the daytime running lights, do not go on.
If I turn the headlight switch to the park light position, the park lights work and also the fog lights do if I pull the green button out.
When I turn the headlight switch to the head light position. No low beam or high beam, also no fog lights on low beam.
If i pull the low/high stalk to flash the high beam, they work.
Any ideas to the problem? Hard to drive on just the park lights and fog lights. Headlights would be nice. Have already checked all the fuses and they are good.
Thinking either the headlight switch of ignition switch?
Something electrical is terribly wrong. Note: the foglights should go off when the hi beams are turned on. I think your suspicions of the switches are spot on, also check for bad connections, frayed wires, bad grounds etc.
Maybe try jiggling the switches before you start ripping into things. Ignition switches, I've been told, have been known to become intermitten especially if the key ring is dangling a lot of weight.
