964 Forum 1989-1994
RPM clock problem?
Old 09-06-2009 | 03:37 PM
Alexx's Avatar
Alexx
Default RPM clock problem?
I have small problem with RPM clock! When I hit throttle and release it pointer is falling down slowly bit by bit ( she is stuck for a second every 4-5 millimeters)!
Do you know what is the issue here? maybe mechanism inside needs cleaning?
Old 09-06-2009 | 04:44 PM
Indycam's Avatar
Indycam
If you rev up the motor to near red line and then switch off the motor ,
does the needle drop smooth or does it stick on the way down ?
Old 09-06-2009 | 05:43 PM
Alexx's Avatar
Alexx
I tried now and needle stayed in 6500,6400 rpm. What does this mean?
EDIT: I also noticed when the engine is hot needle is also sticking but much less!
Old 09-06-2009 | 05:50 PM
Indycam's Avatar
Indycam
The spring on the meter movement has broken .
Thats my guess from half a world away .
Can someone else close to their car do the same test please ?
Does the needle stay or does it swing back to the low end peg when the motor is turned off ?
Old 09-06-2009 | 05:53 PM
Indycam's Avatar
Indycam
If you tap the glass , does the needle move ?
Old 09-06-2009 | 05:55 PM
Alexx's Avatar
Alexx
yes it moves.It` s coming down
Old 09-06-2009 | 06:21 PM
Indycam's Avatar
Indycam
I take back what I said about the spring being broken .
Your testing it by tapping ...
My new guess is that the movement is sticky .
Foreign matter or gummed up lube .
Its not the signal to the tachometer making it jumpy .
The fault is in the meter movement itself .
You can pull the cover off and have a look see at the movement ?
Old 09-06-2009 | 07:39 PM
Alexx's Avatar
Alexx
Check this out:
I made little test now. When the car is COLD needle movement is disaster, also when I hit the throttle and turn off engine needle stay on 6500 +/- RPM.
When the car is on normal running temp. needle behavior is much,much better. it is sticking oh her way down but much less! And when I hit the throttle and turn off engine needle comes all the way down...
This is insane!
Old 09-07-2009 | 02:28 AM
Indycam's Avatar
Indycam
Some new lube for the movement bearings would not hurt .
Old 09-07-2009 | 05:19 AM
Alexx's Avatar
Alexx
That is inside clock or?
Old 09-07-2009 | 06:28 AM
Alexx's Avatar
Alexx
Does anyone know how RPM clock is connected? Through computer or ignition coils? I also have board computer in it!
Thank you
Old 09-07-2009 | 01:33 PM
Alexx's Avatar
Alexx
In case I can say goodbye to my REV counter does anyone know can I use 993 REV counter? I found two of them in LA dismantler! HERE and HERE
Thank you
Old 09-07-2009 | 03:04 PM
Indycam's Avatar
Indycam
I think your old tachometer just needs a little oil .
Please do not do business with L.A. auto dismantler ,
they are not good people .
Old 09-07-2009 | 04:20 PM
Alexx's Avatar
Alexx
really? I did some business 2 times and I was more than satisfied!
BTW I solve tacho problem. Little shaking, hitting, contact spray and it`s working
Old 10-19-2010 | 12:48 AM
sml's Avatar
sml
Thanks for the tips Indycam.
When I pull out my tacho, is it easy to access the internals of the rpm tach guage to give it a clean and oil?
