? about Check Engine Light coming on briefly after start
Having a bit of issues with my wife's 93 C2 that I hope someone knows the cause. Last week the check engine light started coming on (it was a hot day) after start up, but dose not stay on for long. It happened to her after she had driven the car for about 45 minutes and stopped for a few minutes to pick up something. She said that she noticed the CEL when she staretd the car, but then went out. I do not know if the AC was on.
I drove it for one day to check it out. No issues in the morning 40 mile stop and go commute, but in the afternoon, the CEL came on when I first started the car with the AC switch in the on position and fan on 3. Again the CEL did not stay on long. Also, the engine died a couple of times when I came to a stop sign and took a few seconds of cranking to start the car again. The car ran fine for the rest of the commute home. BTW, all this happened after we returned from a DE.
The car seems to run fine and the mechanic says that he has driven the car a couple of times and could not replicate the CEL and there are no fault codes, although one time the car did not start quickly.
Has anyone else had similar experience?
TIA
TIA
I doubt this is the case, but have you adjusted the cruise-control cable lately?
I took the slack out of mine when I first bought the car, thinking it was the throttle cable, and made it a little too tight which brought on the CEL. With the car running, I loosened it until the light went out and stayed out.
I am in Central NJ. If the problem continues, I will look into finding Scantool or maybe finally give in and buy a Duramatic (sp).
I do not know if they ther reseet the DME. I doubt it since no codes were found.
If you start a 964 with your foot on the gas pedal, it will produce a check engine light that will stay on for a temporary period of time and then go out after a minute or so, leaving no code stored in the DME. That means either the idle contact switch at start is a potential issue causing this (easily tested by barely pressing the gas pedal and starting the car - pretty sure this isn't the problem) or the O2 sensor is a potential issue (ruled out by pressing the gas pedal further at startup - 3/4 of the way). That's where I'd be searching... things like O2 sensors do wear out.
You are welcome to drive up, if you care to, and we can run the hammer to read any codes.
Cheers,
Dave
The car is still at the shop where the tech is also trying to do some reserach on the symptoms. I will ask him to try Garrett's suggestion and check the O2 sensor.
I am back at trying a few things. What do I look for with testing the O2 sensor as you describe? No CEL or CEL?
Hi Nader - I'd check your idle switch first by moving the throttle with your hand and listen for the click of the switch (first way to check it) - best way is to confirm with the Hammer which will tell you when the switch is on and off and working properly. I know a Hammer will also tell you the working voltage of the 02 sensor while the engine runs - I've found bad sensors that way a couple times.
