Wider rims and tyres on 964
ah .. ok ... a bit concerned now. Had thought this was very common and an easy fix... will get it checked before purchase. Thanks v much!!!
Does anyone have a ballpark figure for what the cost is to fix the rust spot under the windscreen?
Man of Way Too Many Avatars
Generally speaking, that setup will reduce the understeer on an otherwise stock vehicle, but will not eliminate it. Technically you could go up to 245 wide in the front and 275 wide in the rear, with the help of spacers and flattening the oil line in the right rear wheel well.
If they remove the screen without breakin it then id guess at £200-400.
A new screen is about £300ish.
I had a similar repair done last year, cost £200 to paint/repair round the screen edge.
great - thanks v much - have had it looked at - only surface rust in small 1cm patch
a few other interior pics:
