Climate Control Unit for 964
Hi,
I am wondering could anyone help me with an issue i have regarding my climate control unit for a Porsche 964 (1990 Carrera 4) which for some reason has stopped working in my car, i have checked to see if the unit is still working by pugging it into a friend of mines 993 and it works perfectly, therfore i can only assume that there is some other underlying problem. I have also tried bypassing the relay to see will the unit work and is it the relay that is at fault, but this has not solved my problem either, as the unit does not work either when this procedure is done, i have also checked fuses?
i would be greatful if anyone out there has any suggestions on what else i could check for to help me get the unit working again?
New Member
Ireland
New Member
Ireland
