PSS10 setup
I don't really have anything for you - I do know that with my H&R coilovers, I have around 3-4 complete threads left underneath the spring perch adjuster...but that doesn't really help you I wouldn't think.
Do you have a spring compressor? If so, just make your best guess on the height , lower the car and see where you're at. If you don't like it, compress the spring and make the necessary adjustments.
Keep in mind that if you get the car corner balanced, the shop is going to move the spring perches a bit so don't worry about getting everything 100% perfect.
Call me if you need anything.
