Missing
Most of the time my engine runs just fine, but once in a while it seems low on power/sluggish and it will also develop a mis, and then all of a sudden it is back to normal. Any ideas, your help will be greatly appreciated.
Indycam, nobody here on the island have the hammer, I think maybe a trip to the mainland would be in order. It feels like a loose connection not sure but very annoying. I have another question regarding the CEL; when I start the car the CEL will sometimes stay on for 15 seconds or so, other times not at all; is that normal?
The only time in over seven years of ownership that my engine did not run great was when I started to have high-voltage breakdown in one of my coils. That problem was intermittent at first. Lots of 964s got new coils recently, and there are numerous posts. The scantool said I had almost every code possible - the electromagnetic interference from the stray voltages does that.
+1 on Garrett's suggestion to check the AFM, particularly if the car was ever over-filled with motor oil.
Both my coils have been replaced, one about 2 years ago and the second only a month ago. The problem started this spring when I first started the car after 5 month of winter storage. I had done some maintenance over the winter,
new fuel filter, had the injectors out and tested and of cause oil and filter change. First I thought it was a loose connection on one of the injectors, because it was only running on 5 cylinders, then suddenly it ran just fine and did so for over 2K miles, up until lately when the problem showed up again. I have a spare coil, so I will replace the one that was installed 2 years ago to see if that makes a difference.
I know the problem with critters, but no sign of them in my garage. I leave a few packages of soda crackers in stratigic places, if any critters around they will chew holes in the packages, then I bring out the heavy artillery.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Any chance someone will lend you a code reader ?
Or maybe you could buy the thing ?
"I have an extra ScanTool kit. PM me, if you are interested."
Rocket Rob 04-27-2009, 11:39 AM
I recently resolved a hesitation when cold under 4k and other misfire issues by disconnecting and reconnecting the low voltage leads to the coils.
At first I thought one of the coils was dead, but it turned out that it was just corrosion on the leads. I would disconnect them, hit them with some de-oxit and reconnect and make sure that they snap tight on re-connect.
As has been discussed in the other coil/distributor threads, I found that running on only 6 plugs created a serious hesitation when cold and I had to really feed in power when starting from a stoplight to avoid it bogging down. Now she's purring great.
Good luck!
Good luck!
Thanks for all the input.
I changed the 2 year old coil out for the one I replaced a month ago; keep your fingers crossed, because the car runs just perfect now. Hope I found the problem.
Is there an alternative to the Brasilian made Bosch coils, they seem to be very unreliable.
I would like to check the AFM, but do not know how to do that, any help would be greatly appreciated.
