HE/Exhaust Manifold Gaskets - Victor Reinz
Just received a new set of Victor Reinz heat exchanger/exhaust manifold gaskets from Pelican Parts, P/N 71-24953-30 for the '90 C2. They are different than the previously installed mostly-round gaskets - they appear to be VR's multi-layered steel gaskets. There's a completely flat side, and a flat but slightly beveled side. Does the completely flat side go against the manifold flange, and the slightly beveled side against the cylinder head?
No additional gasket sealant is recommended, correct? How best to hold these gaskets in place while installing the manifold? Looks like the three passenger-side gaskets, maybe originals, were held in place by 3 dabs of black HT grease. They're still attached to the cylinders after removing the HE/EM. The three driver-side gaskets, not original, were dry and fell out with the HE/EM removal. I've read about super-gluing the gaskets to the cylinder, or using tape which is removed prior to wrenching.
I emailed these questions to Pelican and Dana/Victor Reinz in Germany. Dana/Mahle/Victor Reinz in the US doesn't sell or support these gaskets. Pelican doesn't have an answer, and Dana/VR-Germany hasn't responded.
BTW, lucky that exhaust manifold nuts were easily removed, with only slight rust present. Might be the mostly dry CA environment?
I just did this last week and used a small dab of silicone adhesive, inserted the seal and then rotated it to spread the "glue."
As for the orientation, you may want to dry fit the part to see if there's a better fit--one way or the other--but I think your guess is correct. The flat side mates up to the HE flange. You could also pull one of the Factory seals for comparison. If I recall correctly, they're not exactly the same on both sides.
Good luck. Remember not to over torque and use anti-seize.
I just went through the same problem and found the answer in my 964 enthusiast's companion book. the beveled edge of the washer faces the heat exchanger. Put two small dabs of crazy glue on the flat side of the washer and press it into the manifold area. It works great I just finished my car
96foe, thanks, found the reference to "a fine seam on one side of each (sealing) ring", page 443 of the 964 Enthusiast's Companion, and that the "seam" should face the heat exchanger. The "seam" of my previous rings are a flat surface. However, there's a big difference with the VR gaskets' beveled surfaces against the manifolds, as the VR flat surfaces would be against the cylinders, instead of a round surface like the previous gaskets.
To summarize, the cross-sections of the previous gasket seals are mostly (3/4) round, each with one of the sealing surfaces having a very slight built-up flat, aka "seam" by Streather. These flats were installed against the manifold flanges and the round surfaces against the cylinders. The cross-sections of the new Victor Reinz gasket seals are nearly square, formed by multi-layered steel, with one sealing face completely flat, and the other with a raised, slightly beveled lip. Both VR surfaces install into the cylinder recesses with no apparent differences, however I'm thinking having the beveled, raised lip/surface toward the cylinders may eliminate interference between the gasket outer lip and the outer corner radius at the bottom of each cylinder recess.
Hopefully Victor Reinz-Germany will reply with the definitive answer. I was reading about the VR multi-layer steel gaskets which supposedly better resist compression over time, and eliminate the need to go back and re-torque the nuts.
Received answer from Dana/Victor Reinz - Germany:
----- Original Message -----
Sent: Friday, July 24, 2009 6:18 AM
Subject: WG: Re: Antwort: WG: Victor Reinz Exhaust Manifold Gaskets
finally your mail reached me.
Enclosed is a picture and the side you see goes to the head.
Attention: Never ever use any sealants when using a Reinz gasket as long as otherwise described.
Regards
Günter Straub
(See attached file: 702495330.jpg):
Here's my picture of the VR gasket's "beveled" side:
and the flat side:
Regards
Günter Straub
and the flat side:
