crank case cracking?????
Looks like crack to me.
You have 2 choices, sell the car or drive it until it leaks then you'll be concerned at what to do..
I wouldn't spend a dime on expensive analysis procedures cause you'll need a new engine if it's a crack or pay for the expensive analysis + assembly of the engine.. Either way you're going to spend a small fortune.
What if it's nothing?
Drive it until the oil pressure light goes blink! (if that ever happens)
Good luck.
Good luck.
But I want to say one thing... to the American people...:
I did not jack up that car -- Miss 964 -- by her crankcase.
I never told anybody to lie... not a single time. Never.
These allegations are false... and I need to go back to work for the American people.
I would scrub that areas very thoroughly with brake cleaner for a better look at the cracks without any oil or grease at those lines.
Then, I would have that Zyglow'ed to determine whether they truly ar cracks or not. This is a crack-detection procedure for non-ferrous metals.
The case is aluminium and can be welded in that area, however the engine MUST be totally disassembled and the case degreased on both inside and outside before this can be properly done.
Good luck.
Good luck.
Are your marks raised or are they cracks too?
Being an ASNT certified casting inspector of aluminum and magnesium castings with over 25 years experience inspecting castings through penetrant (magnaflux, zyglo as stated elsewhere) radiographic and visual inspection methods . I have to say the photos are inconclusive and far too low resolution to determine if it is a crack.
This could be a surface irregularity since there is a thin surface skin created by the casting process. This could be the result of removing the part too early or not perfectly square with the die while removing it during solidification. Then again it could also be a crack although I highly doubt it. The impact needed to crack a casting like that would be far greater than what we are seeing and if it did crack I would expect to see some oil seepage and far more damage more than likely an indentation deforming the casting from the impact.
If you would like, send me a high res picture and I will take a closer look. Otherwise now that you have thoroughly cleaned it drive it for a while and keep an eye on it. If you notice oil seeping outwards from the crack you have an issue. Although as I said I highly doubt you have a serious issue.
+1 on cobalts comments, I've seen similar looking casting flaws in 911 cases since early motors, and a crack in that location would be leaking like a sieve, the marking on case suggests it got dinged but IMHO its not worth loosing sleep about...I'll bet everyone on the board could go home and find a similar looking flaw on their cases...
On a die used for casting,due to the extreme heat involved,over time cracks will appear in the die.These cracks will show up on the casting as raised marks where the alloy has cast into the cracks or sometimes a line of alloy will stick to a overly hot part of the die and cause a small fisure in the casting, so if the line is raised above the surface it's nothing to worry about,if it's into the surface it's still not 100% certain to be a crack.
Run your fingernail over the surface to see if it is raised material or if it is below grade/surface. If it is raised we have an answer if not we can still try to help although these things are never easy to determine through pictures.
