C4 brake booster not turning on
I did a forum search with no luck. I have a 1989 c4. When I started the car today the brake boost pump did not turn on. Braking was impaired obviously. The pedal will move a couple inches and then get hard. The car does stop, but it is dangerous.
I did not get any warning lights. A few months ago I flushed the brake lines, but it has been fine since. The brake reservoir is full.
What should I look at first to find the problem? What would keep the pump from turning on?
Lack of signal. There's a pressure switch on the pump (green). If it fails to indicate the correct pressure then the unit will not operate correctly.
Are there any leaks in the front boot? Look under the spare tire. If the pressure switch fails it can leak.
You have no warning lights at all? Seems strange.
Have you access to a Bosche Hammer to check for diagnostic codes?
Lack of power. Have you looked at the fuses and relays?
Thanks.
Unplug and plug in the connectors to the pump a few times .
The power connector and the switch connector .
Then see if it starts up .
"You have no warning lights at all? Seems strange."
If the pressure switch has failed in the "I'm seeing full pressure" state , the computer would think everything is pumped up and ready to go . The computer would never tell the pump to run if its being told bad info .
You are both right. I do have a small leak and the connector sensor is off. The leak appears to be from A in the photo. The sensor B will not hook back into place. I am not sure what needs to be replaced or what the next step is.
Please tell me I do not need to replace the $2000 booster pump.
Mucho thanks Indycam and dfinnegan.
After some review, I believe you are correct. I have no idea how it broke, started, leaking and the sensor broke off while being parked, but hey it is only $300 new to get her back to ship shape, bargain I say.
Anyone work on your car lately?
I've just cut open my old pressure switch (new thread to follow) and it was difficult to remove that electrical component even after cutting a third of the housing away. That switch took one heck of a shot to snap open like that!
It does look like the switch took a hit on top, but I am confused how that could happen as it has been parked for the last week. It was working perfectly when I parked it.
Is the switch replacement a serious job? What do I need to bleed? I am a considering taking the car to a pcar shop with a hammer for a look.
You will need a hammer to do the bleed as you'll have to bleed the locks. The job is not bad, but the pressure switch can be difficult to remove. Too bad we're so far apart. I'd be happy to do the job with you. I'm in Warwick, so 4-5 hrs from you.
