18" wheels for DE
MY02 are not that bad. CCW is pretty light. C10 will both be front and rear under 20 lbs. Thanks for posting the numbers and like I said, cayman wheels are heavy. Almost two pounds more when you compare an 18X8 to a fikse 18X10.
Location: San Sebastián de los Reyes, Madrid (Kingdom of Spain)
What about "Speedline for Porsche" wheels?... Are they light?
I would like to use it for track days in my 1991 Carrera 2.
David
David
The speedline wheels are heavy and so are Cup I's but no heavier than most Factory alloys. The speedlines weigh a few more pounds but when adding tires the weight is about the same as Cup I's with equal sized rubber.
I run Fikse's Mach V's for track use 225 on 8 x 18" fronts and 265 on 9.5 x 18 rears i have over 7k track miles and so far no signs of any issues. BTW the Fikses with rubber weigh far less than the Cup I's and it is noticeable.
BTW I don't use the steering rack brace and don't feel it is needed.
