How do I remove the big loudspekaer in the door?
How do I remove the big loudspekaer in the door? The little one can easily be removed by just turning it around, what about the big one?
IHI KING!
Assuming you have the stock factory speaker grills, you gently pry the cover off. Once you do, you will see the speaker is attached to the door panel with 4 phillips screws.
