DME relay
In the front fuse box in the trunk of the car under the light, their are some relays (small plastic boxes). The DME Relay is, I think in position R41 (check on the label inside the lid). Get yourself a new one and change them over.
Here's a pick of a 993 fuse box showing the relays etc. The DME Relay might not be in the same position as indicated though, so check on the lid!
PS - They just pull out, but may be a bit stiff!
These great photos you guys do are invaluable! Very, very helpful.
I didn't have a DME relay problem, but a rear blower problem and the photo helped me fix the problem perfectly.
Just been down to my local OPC to buy one of these as a spare. They wanted £62 and didn't have one in stock. Where's the best place to get them these days? Read a fair bit about them prior to buying my 964 and it seemed the general consensus was they were £20-30. And now I look at those pics above, those '53' relays are exactly the same as the stockpile I've already got from countless mk2 Golfs. So is there a chance I've already got a DME relay at home already and I just don't know it?
Cool, thanks - that's much more like it!
It's not a Porsche manufactured one, but likely the same thing and you could buy 2 for less in case one breaks!
It's the same as I've had in my car for about 4 years and no issues to-date.
Yeah, found a genuine one on eBay for £30. Wasn't sure about getting non-genuine unless it was OEM, and I have no idea who the OEM actually was... Spotted a few on eBay for £20-ish but wasn't keen as I'd never heard of the manufacturer, and if it does fail I want the replacement to work!
