Air Deflector (front brake) Part #?
I need a new 'air deflector' for the right front brake (attaches to the control arm).
I looked on the left on and could come across a part number to help reference for the right one. Searched on Pelican and only came up with 993 deflectors. Could they be the same(they look different...)? Or does anyone know if the mount points are at least the same?
Part # for the 993 right - 993-341-084-00-OEM left - 993-341-083-00-OEM
They look bigger than what is on the 964 (have an upper portion).
Thoughts?
Thanks!
Thoughts?
Thanks!
Thanks! crazy though...$58.50 for the 964 vs $13.50 for the 993. The 964 feels like a hard rubber. The 993 looks like a hard plastic...
And...
After taking a closer look, the 993 (from the photo on Pelican) and the 964 look to have the same overall shape. Could be a matter of mounting points though too...
Going to see if I can find a local with a 993 that will let me test fit theirs on mine.
And...
Didn't need a test fit...but the mount-bolt centers are 4.75" on the 993 & 964. I am going to order a pair of the 993 (always nice to match
) and will give a heads up on the fit when I get them. Just a good FYI replacement should one get torn up...or go missing (in my case...).
Realize it's been over a month, but I just fitted the 993 deflectors to my C2.(arrived yesterday with some other ordered pieces...namely a couple DME relays!) No issue with the fit.
993.341.083.00 air duct /L
993.341.084.00 air duct /R
They have a slightly (a more formed scoop) different shape vs the stock 964 deflectors and are more rigid due to being made from (what I assume is an...) ABS plastic vs the spongier hard-rubber of the 964. Not exactly a typical replacement item; but if you need to, they're readily available and cheap!(under $11 each from Sunset)
Thoughts?
Thanks!
Thoughts?
Thanks!
00, 084, 341, 964, 96434108301, 993, 99334108300, 99334108400, air, brakes, deflector, deflectors, duct, front, images, o83
