964 Forum 1989-1994
964 turbo front rotors, slotted. anyone know where to find some?
Old 05-27-2009, 04:50 PM
mark kibort
mark kibort's Avatar
Default 964 turbo front rotors, slotted. anyone know where to find some?
Does anyone know of a sourse for 1991 964 Turbo front rotors that are slotted, not with holes. Im having some bad luck with the holes cracking badly after only a few weekends racing at the track. dont know if i want to go solid rotors, as slotted would be ideal.
thanks
Mk
Old 05-27-2009, 04:57 PM
mpeters951
mpeters951's Avatar
brakeperformance.com Admittedly a bit of a cheezy looking site. I have the their slotted rotors, perfect fit and perfect track performance, zero issues. not affiliated. zinc'd slots, hat and internals were a plus.
price was untouchable. lead time was ~ 10 working days, as they cast to order.
Old 05-27-2009, 08:17 PM
LouZ
LouZ's Avatar
Location: Philly Area ----- George Washington took a dump in my backyard!
Just bought Cryo treated slotted ones from powerstop.com (they are for a NA 964, so I'm not sure that they are the same)
Old 05-28-2009, 12:56 PM
jim_l
jim_l's Avatar
drilled&slotted rotors from brakeperformance here as well been out for 5 DE's with them no issues, using semi metallic pads.
Old 05-28-2009, 01:11 PM
BlueHeeler
BlueHeeler's Avatar
+1
I put the dimple-drilled and slotted on my car. The price was worth the a risk of a newish to the internet company.
The fit and finish is perfect. There is no rust on the hats because of the zinc coating. So far so good, but it has only been a couple months. They also have a lifetime warranty against warping.
There are some bad reviews of the company on the internet, but they are all the same moron.
Old 05-28-2009, 01:49 PM
cobalt
cobalt's Avatar
Received 2,176 Likes on 1,303 Posts
You can try here.
http://www.zeckhausen.com/StopTech/consumables.htm#Hats
Or you can call Paul from protosport 973-839-5353 he usually has access to custom rotors and brakes that I have not seen anyone else have access to.
Old 05-28-2009, 04:42 PM
CWay27
CWay27's Avatar
Do you still have a proportioning valve?? I had removed mine on my RSA and it worked fine. Even on the track I found that the front brakes were doing all the work and rears were slacking a little too much. After that all four worked perfectly and never had a rear lock up, which I thought was going to happen.
Quick Reply: 964 turbo front rotors, slotted. anyone know where to find some?
