Oil Level Sensor Signal Type?
Anyone know what sort of signal is sent by the oil level sensor? It does not appear to be simple resistance. I want to use the oil level sensor with my MoTeC and the MoTeC dealer I use is not a Porsche guy so he doesn't know and since it's not a simple resistance reading I'm not able to get it to work ... Anyone have experience that will help here?
The oil level sending unit is a resistor based sensor and operates just like a thermister (oil temp sender). Install it on an unused Aux T channel and use the following calibration:
6 ohms = 2
110 ohms = 1
211 ohms = 0
This will show the oil level in relation to how many quarts you need. I cannot remember at the moment exactly how I set it up whether full was showing 2 or 0. On the warm up screen you can use the RPM graph to display the oil level which should be at 1 when idling hot ie in the middle of the two marks on the stick.
Obviously there are many different ways to set it up, this is how I did mine.
6 ohms = 2
110 ohms = 1
211 ohms = 0
Geoffrey: Once again, thanks. When mine was set up Dave didn't know what to expect and all I get is a number that bounces all over the place. This should allow me to get it configured correctly. Thanks.
