OK, now it is hot here! Help with rear fan please
Hi, I am going to take the car out this afternoon. My rear blower fan cycles on and off regardless of CCU control position?????? Somebody mentioned this part
http://www.pelicanparts.com/cgi-bin/...o%2C%20Each%20
but is there a way to jump/test system before I buy a part i do not need?
THANKS!!
Steve
THANKS!!
Steve
Steve,
The part you linked to is a temperature sensor which determines the temperature of the air exiting the engine chamber towards the heat exchangers. The purpose is for the CCU to determine the running temperature of the engine (or, rather, the air surrounding it) in order to allow the CCU to run the electric blower to assist in engine cooling after the engine has stopped.
To determine if the part is faulty, just disconnect it. It cannot then produce any signal to the CCU to mess with the rear blower.
Another possibility is the ballast resistor. This is clipped into the left side of the blower plenum and reduces the current to the blower to provide the slow speed operation. If the resistor is short circuit the blower will run at full speed and it's likely the CCU will shut it off quite quickly. It's also possible you have a faulty relay although, from your description, I'd say that's less likely. You can swap the relay for the oil cooler blower from the front fuse/relay panel in the luggage compartment to check - they are the same part.
Hope that helps.
Regards
Dave
Hope that helps.
Regards
Dave
I just replaced the temperature sensor and blower relay in my car. The rear blower fan was running for about twenty minutes after I shut the car off. Now it doesn't, so it was 50 bucks well spent plus it was an easy fix.
THANKS!!
Steve
THANKS!!
Steve
Hi, My fan starts up the second I turn the key, even before engine start> It runs for 5 seconds, shuts of for one second and on and on???
I am going to swap relays as per Computamedic's advice? I am guessing that big fan is for cabin heat and not critical to cooling the engine? If this is true and my A/C works with rear blower disconnected, that is what I will do short term?
HELP!!!!!!!!
HELP!!!!!!!!
Hi, I swapped relays with no change? What is the purpose of the rear blower? Mine nevedr stays on after shut down? I am going to try out A/C and see how efficient it is?
HEEELP!
HEEELP!
Did you try disconnecting the sensor on the top of the plenum?? At least that would prove if it's the source of the problem.
The rear blower provides the positive air pressure to open the diverter flaps to the cabin when heat is required. It also doubles as additional engine cooling if required after shut off.
The a/c makes no use of the rear blower.
Dave
Dave
I think the next thing I would check would be the ballast resistor. If it IS short circuit, disconnecting it from the wiring should stop the blower running completely. If it still runs with the ballast out it would suggest a problem with the relay (already checked) or the CCU itself.
Dave
Dave
If the blower still runs with the ballast unplugged (i.e. wires disconnected) there must be power supplied via the high speed circuit. I'll have to do a bit of research to figure out the circuit but I think it's beginning to look like a CCU fault.
Dave
Dave
Thanks, i read somewhere it should be upped to a 30 amp. When i started the gremlin hunt I checked fuse for correctness. When the fan cycles, the relay is doing it's job as I can fell it clunking. I just wonder where it gets the idea that it needs to be running? I am going to try the ballast plug even though I recall unplugging it before. If i jump the ballast can I do any damage and while I am jumping, what about jumping/bridging temp sensor?
THANKS!
THANKS!
