clock switch update....can swicth be taken apart to clean??
switch update: today i pressed the switch with great force for 30 seconds and the clock hand started to set the time...it only lasted about 5 seconds and stopped...i tried again with no luck...i pulled the switch and cleaned the contacts on the outer portion of the switch and reconnected wire leads and but no luck...
i assume it is the swith since the hands did move for me..
**can the switch be taken apart for cleaning??
wm
wm
