Clock Ground Wire Repair
The clock adjustment button wasn't working - found a broken wire on the back of the clock which attaches to a black female connector. We believe this is the ground wire -- it is broken at the solder joint - which is inset in the plastic housing - can't see how it comes apart. Curious if anyone else has already had success getting it apart and if you have any tips?
