Scantool error question
Hi, my scantool says "error 12, unknown" for my airbag system. When I look in the error code list it says "fault memory cannot be erased", but not what it means.
Does anyone know what it means and what I can do about it? Because now the warning light comes on every time I start the car.
Thomas
Thomas
the airbag system isn't included in the 964 error code list but I assume it is the same as for the 993. This is what the list says and I have error 12. Or is there an error list for the 964 airbag system that I don't have? I don't have any errors on the Motronic so it is not the code 12 - idle contact ground short.
B02]
;Airbag trouble codes 993
2=Driver ignition circuit to + or 0 V
5=Passenger ignition circuit to + or 0 V
17=Battery voltage low
19=Airbag Warning Light to + or 0 V
73=Short circuit ignition pills
76=Control unit fault cannot be erased
77=Result message cannot be erased
1=Fault memory cannot be erased
6=Fault memory cannot be erased
7=Fault memory cannot be erased
12=Fault memory cannot be erased
13=Fault memory cannot be erased
14=Fault memory cannot be erased
15=Fault memory cannot be erased
16=Fault memory cannot be erased
18=Fault memory cannot be erased
23=Fault memory cannot be erased
48=Fault memory cannot be erased
49=Fault memory cannot be erased
50=Fault memory cannot be erased
51=Fault memory cannot be erased
52=Fault memory cannot be erased
53=Fault memory cannot be erased
54=Fault memory cannot be erased
55=Fault memory cannot be erased
56=Fault memory cannot be erased
57=Fault memory cannot be erased
58=Fault memory cannot be erased
59=Fault memory cannot be erased
60=Fault memory cannot be erased
61=Fault memory cannot be erased
62=Fault memory cannot be erased
63=Fault memory cannot be erased
B02]
If you are not getting the codes that the accelerometers are bad, then a possibility is that the clock circuit is the culprit. I had the problem of the solder connections being shot on the circuit board a few years ago, and followed the DIY by taking the clock cluster apart and resoldering the connections.
Since then, no light!
