America GS Consolidated Thread
#121
No, it is very much a Porsche and could not have been done without the help of many engineers and others at Porsche AG. And, with the engineering done, the 20 year old Porsche weighs 1000 lbs (453 kg) less than the GT2RS even with the weight of the Tiptronic transmission and of the specially made Porsche AG roll bar (covered in leather).
#124
Nice piece Robert. hogged out of Billet??
I could have cast that for you but it would have looked like a casting. A high quality casting but a casting none the less.
Looking forward to seeing the final product.
#126
Location: Dallas, then Annapolis - now Laguna Beach CA. Well, not so fast - I'm back in Dallas. For good!
1 Post
Almost finished machined magnesium transmission adapter ring. ??
Geez, Bob - what's left to do? Oh, coating...
#128
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
You know what!? In second thought, go for it! Lime green would look great!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
#129
Thank you. And I so happy about the engine -- 445 Real (i.e., on a certified engine dyno) HP and 438 Nm of torque from a normally aspirated air cooled two valve engine. Now for the design and manufacture of the final lightweight parts so as to substantially decrease mass, particularly rotating and reciprocating mass.
#130
![](https://rennlist.com/forums/attachments/964-forum/452287d1276732527-america-gs-consolidated-thread-crankshaft-1.jpg)
Oh man!
![](http://forums.rennlist.com/upload/drool_copy1.gif)
#131
I've heard that modern Mg alloys are much more corrosion resistant than the ones on the older 911s (e.g. engine cases & 911 transmissions).
- Is this true? And, if so, what did they do to improve the alloys?
#133
There have been advancements in controlling alloy purity and corrosion reduction however it is still magnesium and susceptible to corrosion if not properly protected. This has been known for close to 40 years and has been applied to military aircraft since the 70's and became more popular in the 80's. Studies going back as far as the 40's were being performed but limited application never amounted to much development of lower corrosion higher purity alloys. This also depends on which alloys are being used for what purpose. Some alloys are basically the same as they were back in the 30's others are just a variation of a common alloy controlling the primary corrosion causing elements such as Iron, Manganese and Copper. by reducing the quantity of the element and controlling the ratios it helps control corrosion although acceptable levels are still 50 mpy for a simulated one year corrosion test.
Some new alloys have been developed but practical applications are limited and cost is high.
Dow metals standardized chemical conversions or surface treatments for magnesium alloys way back in the 40's. These will reduce corrosion considerably but if the surface treatment is damaged and exposed to the elements it will corrode.
#134
The GS America is mentioned on page 166 of Classic and Sportscar magazine July issue. The article profiles an owners 964 Speedster, which was commissioned and built after Speedster production had ceased; it was custom built though the Exclusiv program. (It's a RHD Speedster, btw).
I'm quoting the article
'Production of right-hook Speedsters ceased in June 1993 so, when the order for one more car came in, Porsche Exclusive was commissioned to hand-craft it in Werk 1, the very building in which Porsche was launched. Alongside would be the 964 America 3.8 GS Hardtop Roadster, ordered by a New Yorker and scheduled to be the last 964 made.'
