Hesitation / judder (electrical)
I've got an issue whereby the car stutters for no apparent reason at cruising speed.
It has to be electrical because all of the power (even dash lights, stereo etc)
goes off for a fraction of a second each time it stutters.
The pain in the butt is that it's intermittent (normally only happening on a long run)
and I can't recreate the fault.
I've fumbled around the ignition key wires, but nothing seems to affect it.
I've also cleaned and polished the front earth points and ensured that the battery
is really well connected.
I notice that lots of people have trouble with the ignition coils, but that
wouldn't explain the dashboard lights going out would it.
An obvious weak points I should check?
Cheers
Rich
remover over night) and refitted. I guess it wouldn't do any harm to replace it altogether.
I'll get one tomorrow.
The reason I didn't before was that I figured the car should run fine even without the
battery connected at all as the alternator should provide enough power. So to my mind
the battery earth is pretty much redundant.
But what the hell... I'll try anything.
Rich
Andreas
Also, there is a ground strap from one of the nuts that holds your starter in the transmission bellhousing, the one (bottom) that can be reached from just under the car...this bolts to the "hoop" support for your rear shocks...this can be a MAJOR culprit.
My check list looks something like this:
Air flow meter wiring - my car is a '91 so I didn't have to remove
the protective wire covering, but I did the wire tie and also found
that the breather pipe bracket was floating around as it had not
been reattached by the last owner when the shock absorbers were
replaced. That has been bolted back down and bend as per the
PDF instructions.
Battery earth cable - I've ordered a custom made earth cable which
is really chunky.
Starter to chassis earth cable - I did the starter motor recently and
went to extreme lengths to ensure that it made a really good connection.
You can see what I did here.
In addition, I have also ordered a thick custom cable to connect from the
engine bay chassis earth point to a large bolt on the aircon compressor.
So this should ensure a good ground to the engine/transmission.
Connection to engine management under seat - I'll disconnect and
reconnect as suggested.
Will let you know how I get on.
Thanks for all the suggestions so far. Really appreciate your help.
air flow meter wiring because the problem is still there.
The hesitation was accompanied by the infamous "Christmas tree" illuminated
dash board (see picture).
Let's hope the new earth leads fix it. They should arrive tomorrow.
Leads arrived today. Very impressed with the service of the company making
them up (Kojaycat in the UK).
Sent them all the details yesterday afternoon. Had an email to say they had
been made up and posted the same afternoon. Arrived this morning.
Lovely quality too (check out the pic). Nice rubber boots on every terminal.
So I've replaced the old braided battery earth and added a cable from the
chassis to a big mounting bolt on top of the aircon compressor.
Has it worked? Well I took it for a short test drive and it seems ok. I'll report
back either way after a proper run. If this fails I guess it'll be Jonny's plan
of replacing the coils.
Here are the specs for the cable. The diagram here shows the braided battery
cable replacement at approx the same length as the original (I did mine a bit
shorter because I have a battery disconnect switch attached).
The longer engine/chassis ground cable connects to my aircon compressor bolt.
If you don't have aircon, obviously the length to a suitable bolt will vary.
As you can see from the photo I allowed plenty of slack in the longer lead
to allow for engine movement. Don't know if it hampers air filter removal -
haven't tried. Obviously the cable is pretty chunky and space to get to the
chassis ground is a bit limited, but it's doable.
I think I've got a pic of it somewhere and will post it up if I can find it.
It uses one M8 bolt to secure two earth cables.
My choice of the aircon bolt was very arbitrary. I was just looking for a good,
solid connection to the engine which was easily accessible.
This extra cable is simply an addition to the earthing loop under the car which
Jeff mentions earlier in this thread.
I believe the small braided cable you mention simply ensures a good earth with
the outer (pulley side) components of the compressor.
