Original Cup I's
The 7.5" size was used for 17" 968 optional front wheels-with a little more weight in the front compared to 964's they put a slightly wider wheel. Rears were 9".
There is one other application not mentioned and that was used on the US cup cars that never actually happened. These were the 20 Andial built cars.
I would also agree with the others that they appear to be original.
I found that using the 8" as fronts and the 9" as rears is a nice setup.
if you decide to pass on the set do you mind sharing?
Cobalt if you were referring to me I think I'm going to pass on this set, I really want the 9" rears - I already have a nice set of 7 & 8's. Same to you Brice. Unfortunatley (for you) the wheels are in Italy but if you are interested pm me and I'll see what I can do. Asking price was €500 with tires (probably old and useless ones) I can see if he'll accept less...
It's important that you align all of the wheels before you put the car on the ground. Make sure that the shields are all pointed up.
Good Luck
Code:
Phil
Code:
Phil
So it is only the 2 cars 928 GTS and 968 option.
Between brakes and wheels this info is getting confusing. we need a sticky thread for all this info.
